Slate Truck Dimensions - Length, Width, Height, Wheelbase, Bed Size
Administrator
Administrator
DimensionsSlate
Length174.6 Inches
Wheelbase108.9 Inches
Width70.6 Inches
Height69.3 Inches
Bed Length60 Inches
Bed Width42.9 inches
Ranch3ro 2.0
Kyle
Thunder Bay, ON
Maverick
Ground clearance? And I didn’t get any indication from the press release video, but did they explain why the dismal towing capacity? 1000lbs isn’t even a small boat and trailer, barely a motorcycle and trailer. I don’t see 2000lb as being difficult with this unibody construction. Also no AWD option on a pickup/SUV? By the time these specs improve will
The price be 37,500 before incentives?
mikes
Mike
Santa Barbara, California
2019 Tesla Model 3
DimensionsSlate
Length174.6 Inches
Width70.6 Inches
Height69.3 Inches
Bed Length60 Inches
I'm guessing the bed width of 42.9" is between the wheel wells and if you carry a 4'x8' sheet it would rest on top of the wheel wells? like this photo. Alternatively of course you could tilt it. If so, how wide is it between the bed walls (not wheel wells)?
Slate Auto Pickup Truck Slate Truck Dimensions - Length, Width, Height, Wheelbase, Bed Size 1745681025245-x3
Jturcotte4
Jeffrey
Leominster, MA
2024 Rivian R1S
What is the dimension from the center of each tire? Is the width of 70.6 to the outside of the body panels?
The photo here indicates that you're correct, it would need to be 48+ above the wheel well. If you look closely, the ply is a foot or so above the tailgate. It looks like there's slots molded into the sidewalls above the wheel well to span 2x6s across to make a little shelf too.
